Smog and Cylinderhead Question
davbell22602
Bunker Hill, WV
I Dont
Have
One
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Looks like the small blocks used an air injected exhaust manifold in their IMCO smog system.
The big blocks had a different system called Thermactor that injected air behind the exhaust valve via a drilled/tapped port in the head to which a pipe/manifold system was attached.
The only difference I can see between a "smog" head and "non-smog" is whether or not it has the air port tapped and drilled. I doubt Ford would have designed a completely different head for emissions, too much manufacturing costs.
If you don't have an air pump on your truck it's a non issue.
davbell22602
Bunker Hill, WV
I Dont
Have
One
Ok Thanks. I dont think I'm supposed to have a air pump. Just a standard carb engine.
wilson79
