Sear's Craftsman Handi Cut Cutter
Larry Thomason
clinton, Ok
Larry Thomason
R 1500 C1500, C2500
Awesome cutter for Body side moldings, Vinyl over door strikers vacuum radiator heater hoses nice straight cut! Just wanted to share if you hadn't tried it!
Moderator
What @Snoots is hinting at, we need pictures!!!
I vaguely remember the Craftsman Handi Cut name. Was this back in the 90's when Bob Vila was doing the commercials? About the time of the Robo Grips?
Bennyt
Surprise
Ben
I have one. Works well. Use it mainly for cutting hoses. Sold under several brands. Replacement blades available on Amazon.
I have no idea what it is.
I use a hose cutter:
I have both. Mine straight blade cutter is not craftsman though and it's compound leverage,if you're not careful you could lose a finger.
Turbo4whl
Downingtown, PA
Wayne
I have both. Mine straight blade cutter is not craftsman though abd it's compound leverage,if you're not careful you could lose a finger.
I also have a ratcheting cutter. Yes, it will cut anything but steel. I use it for battery cables, 2-0 and 4-0 on the medium duty trucks.
Original
