Rim painting
Michael
Erie pa
Michael
Scottsdale c10
Have these orgianl hub caps need help on what is the best way to paint them and get the lines neat and straight and the best paint to use thank you
Just have to carefully mask them with fresh, quality masking tape. Old and/or cheap stuff often leaves residue behind.
"Trim black" type spray paint will be a good match for the black. The yellow may be harder to match, something like New Caterpillar yellow might be close.
Georgeb
Wisconsin
George
K10 Burb Z71
Yup, I maked and sprayed my black and very carefully hand painted the yellow. My clear is a bit hazey but I didn't feel like stripping it off and buffing the caps so I went with it.
Jarhead79
Mt Vernon il
Michael
To go a step further you could use some fine line tape around your edges, then tape off using some green 3m 1" tape then use a razor blade or exacto knife to cut out the green tape from around the fine line areas, then spray and clear, then pull the tape and fine line off! Could even clear over the whole cap then band paint the yellow or any other color you might want like body color or interior color.
carlgm
Fl
Karl
'85
Not so permanent but plastidip is a good alternative since you can easily remove the overspray.
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Powdercoat would outlast spray paint, especially on aluminum.
87scotty
Central il
Andrew
V20
5.7 for now
You could get really fancy and blast em wets and the shiny spots and buff em perfect but they are hubcaps lol
chengny
I use a wide tipped Sharpie (the new "Extreme Permanent Marker") to touch up any little scratches. It makes a very good match and hangs tight - for as long as I have been doing it anyway:
Michael
Erie pa
Michael
Scottsdale c10
Really a sharpie and its holding up good did you clear it or anything ?
abell385
