Removing smog pump and tubes 84 305
NCTyphoonKid
Trinity,NC
Korey
Silverado R10
What all do I need to do to remove the smog pump stuff? I'm planning on going to headers anyway. What kind of belt do I need to get for it if I remove the smog pump
Swims350
Logan WV
none
get one at the local parts store for one without the smog pump
NCTyphoonKid
Trinity,NC
Korey
Silverado R10
Is there anything special I need to say to get one or would I use a older models belt
Swims350
Logan WV
none
if they don't list one for yours without tell them older one, it's supposed to be an option in their system, without AIR pump. Go online to your auto parts store nearest you on their website, autozone.com advanceautoparts.com etc. enter your info and look it up yourself, if you find it write down the number and go down and get it or order online. If you order over $50 in stuff look online for discount codes, I do it all the time from advance, just saved $40 on a battery yesterday.
Swims350
Logan WV
none
also rockauto.com I buy almost everything from them anymore and on this site and others you can find 5% discount codes anytime.
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
When I ditched all my smog and went straight headers....removed pump, pump bracket, removed belt for pump, removed pump air hose to air cleaner, removed stock exhaust manifold...thats it. In my case with a small block 350...there wasn't a need to get another belt after ditching the air pump.
garzas23
Brazoria County TX
AJ
Yep. If I remember right, the smog pump has it own belt connected to the crank pulley. Just yank it off it will NOT effect the other belts.
87ChevyR10
Kansas
NA
NA
NA
Yup, what Smooth and Garza said. I went to headers myself. AIR pump still attached and belted, though. Need to take belt off before pump decides to seize.
Swims350
Logan WV
none
been awhile since I removed one figured it had a belt tied in with others. I've removed several just forgot.
alwaysbroken
