Short term goal now long term... question on diesel to gas motor mounts.
IDtag
Tod
C30
My 1982 dually build just became a longer term project so need to get it back on the road with a temporary power plant. Currently has a 6.2 that I haven't been able to get running right after multiple attempts. Don't want to put more money and time into the diesel.
As far as motor mount locations on the frame, is the location for the 6.2 mounts the same as a small block Chevy? Know I'll need to swap the torque converter and some exhaust work, put in a relay and wiring for the fuel pumps.
Have a pair of stock tanks with pumps and all the plumbing so am getting those put in the truck. Also have a mildly built TPI motor sitting in the shop that will bolt up to the TH400 so that seems like the quickest way to get the truck mobile. Small block isn't ideal but considering what that 6.2 puts out probably not much of a difference.
Have an 8.1 and 4L80E but if I dive into that right now it'll probably be sitting for another year before I can even get started. With that I'm getting into wiring harness, trans mounts, whole new exhaust, driveline, etc.
Small block,big block,or 6.2 you can swap back and forth on the same mounts.
SquareRoot
6.2 LS. Once and done.
Oliver90_08
