crazy4offroad
Equal Opportunity Destroyer
- Jul 30, 2010
- West BY-GOD Virginia
- Curt
- K-10
- 350/SM465/NP205
When working with cement blocks (DONT use actual "cinder blocks") have the open cores facing up, and put a board on top. I use 2x8s cut to the same size as the block. Then you could use your jack stands on top of them if you set them right, with wood in between. Heavy metal against cement blocks = fail. Good luck!
