new motor
Moderator
I'm aware of that. In this case, I'm referring to using BOTH. Use the Case speedo drive for the speedo, use the Tcase VSS for the ECM signal.
I don't follow. The tranny doesn't have a speedo provision, since there's no tail housing.
Moderator Administrator
That's the whole point I'm making here, a Th400 DOES have the speedo provision in the case, NOT THE TAILSHAFT. If you use a Tcase on a Th400, then you need a block off plate for the speedo provision. So my point is, why not use both. If need be of course.
elstm3
montana
lynn
V30 crew cab dually
6.2 twin turbo diesel
Im not sure if i missed this somewhere but wouldnt the 93 t-case have the drop on the wrong side?
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
I think you can re clock them...the only problem would be the shift lever, if its not electric.
Swims350
Logan WV
none
yes if it's a 93 it would be DS drop, BUT you can find a squarebody burb and get a PS drop VSS t-case.
Yep. Good Point. So you'd need to get an NP241C out of a VSS vehicle. I think that's 89 to 91.
Moderator
Huh, never noticed that before.
...going out to my garage to take a look...
Yep, so it does!
:rofl: I wouldn't have lied. I had pics if you wanted to see, you didn't have to go out in the garage and wade in that puddle of trans fluid.
Moderator
Lol, it's my rebuilt th400 that's been sitting on the garage floor for a couple years. I had never noticed the plug there, even though I was just scooting it around the other day.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
You can't clock a driver drop case enough to make it passenger drop... Fill and drain plugs would make getting the proper fluid level an issue... Then there is that whole vent in the top of the case thing.... A hole in the bottom of the case well make retaining any fluid hard, much less the proper level. :lol:
I do vaguely remember hearing about cruise control trucks having a vss built into the speedometer at one point, not sure what years that covers, orr if it is the right number of pulses.
VFL1982
