new here i have to many toys
aggressivedriver
delaware
carl
which one
all k10 c10 c3500 k3500
i started this to get imput on coverting my 2wd crewcab to 4wd i'd like to find someone who took pics and not trying to offend anyone but someone who did it the right way nothing torched or just cheap made. my name says it all i'm aggressive short and simple i want a beast 454 400turbo 373 gears oh and most important has to have ac. and yes i know you can buy one but thats not much fun and you still end up with a peice of someone elses crap that needs work i know i already bought a beater truck i already have a 4x4 crewcab dually for what ever real reason runs nice just other then motor i have no use for it. and yeah crap most 4x4's around my area are really rusty. personal belief he who dies with the most toys wins. play hard die young
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
^^^^^^^^Oy....here we go again.
Welcome to GMSB.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
There have been several threads started on the subject here but I dont believe anyone has dedicated to actually doing it yet. If any has I dont believe any pics have been posted. If you take it on take pics and do a write up! I think using a torch is an inevitable part of a swap like this. Welcome to the forum! :cheers:
Stumpuller6.5
CANADA
Clancy
C3500 3+3 Long Box Dually
6.5 Turbo Diesel/SM465/D70
I`m on the list to get`er done, but It will be a least a year before I commence that project on mine. :)
Moderator Administrator
Welcome Carl
Rednex4x4s
Kansas City MO
Tony
C-30 Reg Cab Dually 10,000 GVW
cut a 4wd frame behind the front body mounts ( incase you ask wich front mount the front cab mount behind the engine ))))) this way you have all the parts u need and so you have something to measure from. grab the tcase and cross member too .drill all the rivets out so they can be knocked out then swap all the front cross members and suspension mounts . ive done several on mint condition trucks that i wanted 4wd. done several dodges also . they are time consuming and alot of work . you will need tall jack stands lots of drill bits not cheep ones either. and a whole saw for the rear shackle mount to the frame. lots a stainless bolts went back into mine and locktite everything you dont wanna take loose again. LOCKTITE IS YOUR FRIEND IN THESE SWAPS.....
crazy4offroad
Curt
K-10
350/SM465/NP205
Stainless is a bad choice for this, you want Grade-8 bolts!! Stainless has a grade of like 3 I believe!
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
x1,000,000!!!!
Totally Stainless does offer Stainless steel bolts in the right alloy to have enough strength for an application like this, but I would still definitely prefer regular grade 8 bolts, or even grade 9 if you can swing it (McMaster-Carr carries those).
crazy4offroad
Curt
K-10
350/SM465/NP205
After some reading I saw 2205/2304 stainless which is really strong but the most common is 18-8 and hopefully Tony is aware of the difference. Buy your fasteners at a place like Fastenall and ask the counter guy what is best for your application. I'm betting they would recommend zinc coated carbon steel over stainless, but if you got the deep pockets for it they'll turn you on to the high strength stainless.
Welcome Carl, where in DE? I am 20 min nw of Philly.
Weclome to GMSB Carl.
IMO, Converting your 4x4 Crew Cab Dually to 4x4 Single RW will be much eaiser and cheaper than a 2wd to 4wd conversion. Any reason you haven't thought of that instead?
aggressivedriver
delaware
carl
which one
thanks for all your imput i have been reading up on it some i already have two donor set ups as far as why i don't want to convert my 4x4 dually is simple to much rust for what i want and i don't want one ton rears. i live in smyrna delaware. i'm not afraid of doing the rear thats the easy part so is the front spring body mount alittle cautious about the front rear spring hanger. i'm pretty sure i already have almost every thing i need. but i'm courious about i've seen some peoples post about the frame being taller that much i already know it starts just at the front of the cab and until the rear arch of the frame but what are they talking about the cross memeber being different height. any imput on that would be nice
towjoe
Lafayette,IN
joe
78,80,81,81,86,88,89
K30's or V3500's
K30 Center crossmember/frame is over a inch taller at the front spring hangers of rear axle than a K20 of same year. I had to change one out that was rusted in half in a K30 and all I found was a K20 that was handy.
rgorma01
