!!!!Need Np208 transfer case!!!!
silverscottsk10
trafalgar indiana
mike
In need of a np208 transfer case, or input/front wheel drive side of the case
Located in Lima ohio or trafalgar Indiana depending on the weekend
Can drive depending on weekend also to meet or pick up
I really need a case as there's none in ohio apparently
Please and thank you
MadOgre
NA
NA
NA
NA
NA
Im sure one of these guys can at the very least point you in the right direction :)
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
I have a few 208 cases but shipping is a lot from here.
I don't have time to tear out an input gear or that could save a lot of shipping.
what transmission do you have
turbo 350 and 700r4 have the same input gear
turbo 400 and the sm 465 4 speed(85 and up) have the same input gear
in 85 when they first used the 208 behind a 465 they changed the tail shaft on the 4 speed to a long 32 spline tail shaft.
silverscottsk10
trafalgar indiana
mike
I only need the front part of the case
All my internals are good just case has a hole
firebane
Calgary, AB
Curtis
That isn't a hole! That is just a crack. Man I'd grind those edges down smooth to the case and jb weld that bitch shut. IF the jb weld fails.. weld it!
Your way overthinking this that case only holds a small amount of fluid not under pressure. That is a super easy fix.
Georgeb
Wisconsin
George
K10 Burb Z71
If this was mine it would be welded already. I would find someone with a TIG or Heliarc and some experience, push the bend back part into place and have it welded up.
silverscottsk10
trafalgar indiana
mike
I have talked to the college welding teacher and he said they could but there's no guarantee it will hold
Georgeb
Wisconsin
George
K10 Burb Z71
Hold what? Weld it and forget about it! It's not structural.
silverscottsk10
trafalgar indiana
mike
I know it's not load bearing or pressurized
But seeing how difficult it is to get the case I'd like to get one if they refuse to weld it
firebane
Calgary, AB
Curtis
Then find someone else! Tons of people with welders who would do this. As it was stated its not structural and there is no internal pressure.
Anyone who can weld worth a damn can seal this up.
SquareInheretance
