Transfer case shifter handle
fnny6770
Pocatello
3500 camper special
In my 1980 GMC k3500 it has a 454 in it with the manual transmission, I remember when the 400 engine and the th400 transmission was in this truck the four-wheel drive shifter handle was really solid not hardly any play, but when my brother put in this 454 and the 205 transfer case the handle is very sloppy as if it's going to fall off, is there any adjustments that can be made or is this normal?
Strick
Dunn, NC
Harold
C20 Crew
Check the bolt that fastens the shifter & grease it too.
HS
PrairieDrifter
North Dakota
Mason
Suburban k10, bonanza k10, k30, c10, gmc 1/2ton
350, 350, 5.9L 12v Cummins, 350, 350,
There's a bushing in the base of the handle that's most likely bad as most are, if gone long enough the bolt or handle can get wore out too.
fnny6770
Pocatello
3500 camper special
Thanks for the reply, I will look into the cause a Little closer
Shifted
