Looking for Down Pipes for '76 K20 with a 350
zbhover
Glasford IL
Good Morning Everyone,
I've just been mostly lurking for the last couple years, you know collecting ideas to do to my 1976 K20 single cab long bed for when I have time to work on it :) My exhaust is getting pretty rusted out, so I'd like to fab up a new exhaust before winter.
I have everything I need to weld up a new exhaust system for my truck except for the down pipes to connect to the stock exhaust manifolds with exhaust doughnuts. I've been looking for just the down pipes for a while and I can only find them in complete exhaust kits. Does anyone know where I could purchase the down pipes and flanges only, or even short stubby straight sections that I could weld to my own mandrel bent 90 deg and 45 deg elbows? I'd be fine with stock diameter, or maybe up to 2", I just have a basically stock 300hp 350 and I just use the truck for hauling stuff.
Thanks in advance!
Rickf
Grafton NH
1974, 1954 & a 1937
Try searching for pre-catalyst dual, maybe '74, pipes.
legopnuematic
Licensed Junk Dealer
MO
Spencer
I've got a set off of a 75 K5 that was a factory dual exhaust truck. They are 2" pipes. A good exhaust shop might be able to bend you up something.
eskimomann209
Modesto
Marcus
I feeeeeeeel like these should work
Kryptonitekid
Philadelphia, PA
Jeff
CK20
I just finished converting back to stock exhaust manifolds after my headers rusted out. I used the PYPES DGU135 parts below. Order from Summit - although they are GM they are are for G body not for trucks. The driver's side worked great and fit right over the cross member. On the passenger side, since I have a 4x4, I had to insert a piece to drop it below and under the transfer case. Regardless, I thought the quality was really good. I ran 2.5" all the way back with flow master stainless tailpipes going over the rear and then into 3" tubes exiting straight out the back.
Alex123
