I think a rod spun a bearing in my rebuilt 454
Chevy 88
Canada
f7t6
GMC
$5800?
A used engine that is in good shape could not be more than $500 or so. No?
Maybe $400 labor to swap it, no?
Labor was $3200 and parts was $2600 ($5800 all in for a complete long block).
Looks like now it will be more. If I have to replace all bearings due to metal contamination, piston potential replacement, rods, and maybe crank.
I doubt it's that bad. Rods can be checked and resized,crank can be ground,very unlikely pistons got damaged.
Moderator
$5800?
No. Even though it ain't an LS, big blocks still ain't cheap and still fairly difficult to get ahold of.
txaggie
austin texas
kris
suburban C20
I found a crate gm vortec 8100 local that I can snag for $3800 but I bet it will be a pain in the ass to swap. I have the sniper setup for this motor, Afr heads, etc.
Moderator
That's basically going a whole other direction. There's a lot of other parts you would need (like the entire accessory drive) and you wouldn't be able to use any of your existing stuff like heads and cam. I wouldn't go that route, and this is coming from someone that has an 8.1 swap in the works.
Chevy 88
Canada
f7t6
GMC
deleted
Moderator
That's a bummer.
That's a bummer.
Yea,but not hurt bad. Grind the crank resize that one rod,clean,check and double check all oil clearances .
txaggie
austin texas
kris
suburban C20
But a full cleaning, and bearing replacement is needed. I don’t really trust the cook who burned the food to recook me more.
edgephoto
Stafford, CT
Greg
GMC V3500
7.4L
I think you need to pay someone else to straighten this thing out. I would give the current shop a chance to do the right thing and refund your money. If they don't take them to small claims court. You will have a very good chance of winning.
Chevy 88
Canada
f7t6
GMC
This might be your best bet:
txaggie
austin texas
kris
suburban C20
I paid with cc. I can just contest the charge and get a chargeback.
Bennyt
Surprise
Ben
I think Ricko and some others are giving some solid advice and I'd definitely stick with what you already have.
If it's a true reputable machine/ engine shop, I'd give them a second chance as they "should" know what they are doing.
If going to another shop, this is what I suspect you'd pay:
Turn crank, assuming it's not already 30/30 runs $200-300. Lot of good machine shops still send their cranks out. Mark your crank to ensure you get the same back.
R&R rod, press 1 piston, balance 1 rod, etc should be about $100. Core $15-25 if needed. For me, 50% of the time the rod bearing spun, rod twisted/bent a few thousandths.
Gaskets, bearings, $400.
Dissembly, cleaning, assembly $500 plus.
By the time you add fluids, incidentals, etc, you'll be at $2k
Bennyt
Surprise
Ben
Yep, rod bearing cylinder 1
Why are the outer main bolts not installed?
Jeremy89
