Floor Shifter For TH400
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Anyone have any recommendations for floor shifters?
Or does someone have one they'll part with?
Planning on manual VB with trans brake.
Pattern would be P-R-N-1-2-3
Doesnt have to be labeled correctly, i really dont care about. I just want a shifter i can yank down when i launch my shitbox from "neutral"
I dont have a 3 speed auto column, so im probably just gonna roll with a floor shift. I can cut and weld shifter to work so it dont hit bench seat.
Thx
Poppy 87
Bloomingdale GA
R10 Silverado
Go old school, Hurst Quarter Stick
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I like the Hurst Quarter Stick, TCI makes some nice shifters also.
I have seen some advertised for truck with a longer handle, either than or you need to fabricate a shifter mount so your not leaning as far down to reach the shifter. The distance between the floor in a truck is a lot further than a car!!
Vbb199
Salisbury NC
Vince
Yep, that was my concern with squatty potty shifters, i wanna be able to sit back in my seat when i launch it and just pull the handle down
Craig 85
Nashville, TN
454/TH-400/NP205
B&M makers a ratchet shifter for trucks # 80680.
  • Forward and Reverse Shift Pattern Compatible
Vbb199
Salisbury NC
Vince
Wrong tbread post
Moderator
For the average floor shifter installation in a truck, I really like the affordable B&M Unimatic. But with a manual valve body, a full ratcheting type is a must.
Moderator Administrator
I used a B&M Quicksilver Ratchet shifter in my truck. It is reverse pattern compatible and if you ever upgrade to 4 speed, it's also 4 speed compatible. I think Mega shifter is the same too in the B&M lineup as far a reverse pattern and both 3 and 4 speed. you can even get the tall deck for iehter of them too for trucks so your reach isn't so far.
Vbb199
Salisbury NC
Vince
I was looking at unimatic first, but that didnt look to be racheting.
QBuff02
Central IL
Quincy
I currently have the B&M 80680 Mega shifter for trucks in my K30 and i'm more than likely going to swap in a brand new full manual/reverse pattern th400 this summer. As it sits now, I built a plate to mount the shifter on so it's got a solid base, and put it in a location that allows me to have a little range of travel in the seat (i'm short legged) and when you're in gear, the handle is about 3-4" back from the park position. It's at that perfect "sweet spot" for one hand on the shifter and one hand on the wheel. I really like the shifter, it full ratchets and doesn't allow missed/skipped shifts, is positive and has good function. But I also know it is STIFF, no matter what i've tried. and if i'm going to be switching to a full manual valve body in this driver, I have told myself this is probably not the shifter to keep. I had a B&M prostick in years past and will more than likely swap this shifter out for either one of those or a Hurst quarter stick when I make the trans swap. And I will build a tower for the shifter so it fits the position for hand placement just like I did in years past. I would probably keep the current shifter if the driving was only on occasion, or maybe it's just in my head when I think about a full manual valve body on the street with this thing and I should wait and drive it once the trans has been swapped and then decide. but I just don't think this is the one to have for constant shifting. But I will say, you can literally beat it like a red headed step child and it performs exactly the same every time. Just my $.02.
Vbb199
Salisbury NC
Vince
This is all really great info guys, thank you.
I will read up on these tonight, maybe place an order with my manual VB this weekend...
Vbb199
Salisbury NC
Vince
Thx for the pic also... reminds me i need a tach.
NateP350
