Electrical plug for clutch switch...
SquareRoot
I converted my 85 from auto to manual. The new clutch safety switch has two female plugs. One is for the starter interrupt,. not sure what the other is for but it doesn't matter. Anyway, there's no way to use female connectors on it, the male spades are embedded in the plastic plug.
Anybody have a lead on this or able to snip me off the plug from a manual trans equipped square body?
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
I switched the 73 C10 from manual to Auto. I'm not sure if it had the safety switch. Any idea what it would look like?
SquareRoot
This is the switch. It has two sockets. The pigtail I need goes to the side closest to the firewall, left in the photos.
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
I looked in the 73 today, it didn't have any type safety switch for the clutch.
fast68chevy
I am the original fast68chevy
LINCOLN IL
RANDY
its a white pull push switch on clutch pedal linkage. i have one somewhere in my electricals stash, and 84 older is alot different than 85 up, hydraulic vs mechanical.
fast68chevy
LINCOLN IL
RANDY
when did you do this i am looing for all the mech. style clutch link parts incuding the frame rail pivot bracket.. and the front half of 2wd 4 speed driveline and 2wd crossmember too... i need it all, to go to 4 speed in my 75 no one seems to want to help me find parts pieces to ditch my th350 trans i hate autos...
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
I did this 5 years ago, all I did was remove the clutch pedal and all the rods. Mine was a three speed on the column.
boarder421
