Carb Bog
Boone83K10
Boone, NC
Benjamin
Well it could be the power brake line. Start from the modulator and follow it up to the other end. It should be to hooked to manifold vacuum.
John81287
Mchenry,IL
V20
Ok traced it back and it is hooked to manifold vacuum. I guess the next question is could this modulator be bad?
Boone83K10
Boone, NC
Benjamin
I guess it could be
John81287
Mchenry,IL
V20
Anybody else wanna chime in with an opinion? I don't want to just start throwing parts at it
Boone83K10
Boone, NC
Benjamin
When you said you tuned accel pump, so is the arm barely touching accel arm and no pressure is being forced upon it.
John81287
Mchenry,IL
V20
Out of the three holes on the linkage it is in the one closest to the intake what I would say is the bottom hole. It seemed to be more responsive after I did that. I thought about moving it the other way and seeing if that's any better. Can't really hurt anything so I figure y not try it
350runner
tx
Ceasar
Try adjusting the arm to give less of a shot. You can also test this with the arm disconnected and see if you still have the bog
Sent from my LG-LS980 using Tapatalk
Boone83K10
Boone, NC
Benjamin
I meant the adjustment screw. You're talking about the pump cam..you should put the pump cam back then adjust the accelerator pump arm to barely touch the adjustment screw.then go back to the pump cam.
Boone83K10
Boone, NC
Benjamin
ignore my previous post.. too many holleys on my brain. on an eddy you should be looking at the metering adjustment or adjusting the pump cam like you have done.
John81287
Mchenry,IL
V20
Explains why I was confused... I'll have to monkey with it a bit more
John81287
Mchenry,IL
V20
Ok so I broke down and bought a vac gauge for testing purposes. At idle, at temp the vac gauge is reading around 7. According to the instructions that came with it it should be between 17 and 22 for a properly tuned carb. Ok great so I go to adjusting the screws and get little to no change. Currently waiting for the exhaust to cool enough so I can check manifold pressure by the modulator on the trans. I'm kinda stumped with this damn carb. Anybody?
Boone83K10
Boone, NC
Benjamin
Is this a built motor with a lumpy cam? What is your elevation? Answer these 2 questions then we will move on
John81287
Mchenry,IL
V20
Yes it has a pretty strong lope to it. Elevation is flatland. Illinois so I believe I fall in the Great Plains region
Boone83K10
Boone, NC
Benjamin
For every 1000 feet avove sea level you can subtract from that 18-22 inches of Hg (mercury). A lopey cam indicates overlap of valves further reducing inches of Hg. I am at 4200 feet and my truck has 12-14 inches of Hg. Small cam. 7 is an indication of either and extreme cam or an intake manifold leak. Does the needle bounce at all?
John81287
Mchenry,IL
V20
Does bounce a little from about 7-9 not real big bounces here is the specs on the cam.
. I'm around 7-800 ft above sea level. Not enough to make a difference really correct?
Mudbeast2
