brake up grade 1987 c-10 1/2 ton
siataspring850
delaware
mike
c/10 step side
I am going to upgrade my brakes from manual to power. I read in a recent post I would need to change out my brake pedal. Is this true?
My truck is manual tranny with factory front disk brake so it has a proportioning valve block I think I can keep the proportioning valve in place and just add the booster with brackets add a vacuum line from the carb base plate and its done. any thoughts would be appreciated
Keith Seymore
Motor City
Keith Seymore
R10
4.3L
You will need to change the brake pedal ratio from 6.5:1 to 4.5:1.
There may already be the correct hole in the pedal, so you may or may not need to change the pedal itself to accomplish the ratio change.
K
Keith Seymore
Motor City
Keith Seymore
R10
4.3L
Here is the brake chart for 1986, which is the same as 87 (I'm at work and I happened to have this one scanned).
You can see the difference between manual brakes JB1 and power brakes JB3, line by line and part number by part number.
K
alawadhiq8
