Power brake upgrade question
eddiericks
Charlotte, NC
Edward
custom deluxe 10
4.1L
Good afternoon,
I am still new here and this is my 2nd post.
I love the forum and find that like-minded people are best at answering questions and having experience with the same issues over and over.
So I have a 1977 c-10 4.1L 6cyl, 3 on the tree NC farm truck with 77,800 original miles.
This truck has manual brakes - front disc, rear drums, and the master cylinder is leaking.
I have purchased a power brake boosted master cylinder from Master Power Brakes in NC.
I have all the parts needed to perform a full brake restoration - drums, shoes, wheel cylinders, rotors, pads, soft lines, and hard lines.
Question is where to find a suitable manifold port to run the vacuum line from the booster?
I had a '76 model of the same truck that actually had factory power brakes. But that was back in 1986 that i owned that truck - high school.
I do see where the EFE uses a manifold vacuum port on the right rear of the intake. I wonder if I can use that and then route the EFE vacuum via a T fitting to another vacuum line off of the monojet carb? Not sure I need the EFE to work exactly as intended given the location of NC. BUT I do need the brakes to fully work as intended!
I have a photo of the EFE port (sort of hidden behind the air cleaner and a photo of the existing brake master cylinder.
Thank you for any advice you may provide.
Eddie
Converting from manual brakes to power,you need a power brake brake pedal or relocate the position of the pushrod on the pedal Power brake and Manual brake have a different pedal ratio. Give us more pics of the manifold,with the air cleaner off. Most of us have worked on 9000 V8 trucks to every 1 6 cylinder truck,so we need to see things,to help. I'd think there is a spot on the manifold for power brakes.
ali_c20
Austria
Alexander
C20, K5
The brake booster should have it's own vacuum line, not shared with any other thing that needs vacuum.
eddiericks
Charlotte, NC
Edward
custom deluxe 10
4.1L
Understood!
Thank you.
I’m thinking I can use the EFE vacuum port dedicated for the booster, and reroute the EFE vacuum to T into some secondary vacuum port. Perhaps off the carb.
I’ll post a few pics with the air cleaner removed later today. 5-6 pm EST.
Thanks!!
Ed
eddiericks
Charlotte, NC
Edward
custom deluxe 10
4.1L
Ok. I was able to sneak home and get another photo with the air cleaner removed.
I think if I use the EFE port with a different fitting to run the brake booster, i can T in the EFE line to the EGR vacuum line off the carb.
See any issue with that set up?
I don't think a completely correct functioning EFE is necessary any longer if there is a smaller amount of vacuum.
Thank you!!
Ed
Look between the carbureator and valve cover.
eddiericks
Charlotte, NC
Edward
custom deluxe 10
4.1L
excellent advice.
Thanks for the pic.
Ed
CubsFan79
