yocami
- Mar 17, 2026
- missouri
- Coy
- V20 Pickup
- 350ci small block
I've got a 1987 3/4 ton 4wd regular cab longbed, with the C6P rpo code and a full floating axle, it has a load sensing proportioning valve and linkage but its corroded and Im unsure if it is still functional, I'll post some pictures when I can get to it. Im planning on replacing the master cylinder, both wheel cylinders and rear brake hose as well as the drum hardware and brake shoes, I'm thinking I could bypass the LSPV with a thumb screw proportioning valve and adjust it to about 50% if the LSPV isnt functional. I tried to bleed my rear brakes because the previous owner had a way over sized rubber gasket on the master cylinder and it tore apart and leaked the rear reservoir dry, I put the correct gasket on and refilled the reservoir but I could not get fluid out when bleeding, ive heard that the proportioning valve in the engine bay could prevent bleeding but my knowledge is limited with that aspect of the brake system, the master cylinder is getting replaced because I was unaware that fully pushing the brake pedal to the floor could damage a seal inside the cylinder when bleeding, the master cylinder was leaking towards the vacuum diafram housing. Any and all knowledge, info and advice is welcomed and appreciated!
