Rotten 1
- Jan 9, 2024
- Tennessee
- Chris
- C10
RickoI wouldn't condemn the master cylinder so fast. And I don't have $.10 confidence in the things on chat gtp . Make sure the rear brakes are adjusted, jack up a front and rear wheel have someone step on the brakes,see if front and rear work. If you have some brakes but not good brakes,I don't suspect the master first .Unless the brake light is on
Rear drum brakes adjusted - I can get almost one full spin on them with the truck jacked up and in neutral. Everything I have read and seen suggests this is right - unless I missed something.
Jacked up both drivers side wheels and with the wife pushing the brake pedal the front did not move while there was no change in the rear, it moved the same with and without the brake pedal pressed. With the emergency brake on - the rear does not move at all. It seems like I have some braking ability in front (brake pedal all the way to the floor) but not in the back unless mechanically activated via emergency brake.
I'm not smart enough to know what this diagnosis tells me - it seems to say that there is something preventing the hydraulics from reaching the rear, and in the process reducing front brake effectiveness.
I have a master cylinder coming next week and that will be my next step.
What else am I missing?
thanks everyone
