3rd line coming out of master cylinder?
Moderator
I did not make a serious attempt to find out if connecting hydraulic lines to your master cylinder is still “legal”. However, in some states you may have trouble during an inspection if they notice it. It just depends on the inspector. However, there are definitely now newer and better designs to sense vehicle braking and send a signal to the trailer brakes.
I was also too fast in wording my answer about the brake controller wiring to the 7 pin plug. The brake circuit activates the trailer brakes, and “may” ( or maybe not) also be used charge a battery for the break-away system.
"It depends on the inspector"
Yessir, you are 100% correct. There are inspectors (at least one anyway) that don't know exactly what they are talking about and will fail a vehicle for something it should not legally be failed for. California included.
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
Just curious. Does it terminate to a controller or does it dead head somewhere?
FWIW, I was wondering what was going on with the OP's truck. I knew what they were for. Lol
Moderator
Some states may have different laws for trailers. In Pennsylvania every heavy trailer wheel set are required to have brakes. Some states may only require one axle, not both.
When the forum members are talking about fuel injection and other items I don't know enough about, I keep quiet. When wrong info is posted about safety items, I'm ready for the Sh!t Show!
What is the weight rating at which brakes are required on all axles?
Turbo4whl
Downingtown, PA
Wayne
Jimmy
Here in Pennsyltucky, any trailer over 3000 lbs needs brakes and a brake-a-way system. All wheels need brakes. Years ago trailer brakes were only required if the trailer weighed more than half the towing vehicle weight. This led to confusion and misinterpretation.
Trailers over 3000 lbs need a safety inspection, unless it is a tool (implement of husbandry).
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
Craig
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
duncan_schawalder
