Hunter79764
- Sep 1, 2021
- Grand Prairie, TX
- Shawn
- Suburban V20
Not exactly an answer to the question, but a tip I picked up from an old guy on another board. When changing disc brake pads, install a line and crack the bleeder at the caliper, then compress the pistons. You will flush the old brake fluid and do a decent job of getting any air out, then just keep the master full when you pump up the brakes again once the new pads are on. Doing that basically any time you take the calipers off means you have decent fluid in there regularly.
I'm also glad to hear I'm not the only one who has issues with the hand vac pump bleeding method. I've been keeping an eye out for a pressure bleeder, but might look at the reverse bleed setup. And I wondered about teflon on the threads, so good to see that addressed too.
