beyerku
- Jan 4, 2023
- Iowa
- Kurt
- K20
I can't figure out my brake problem. 1975 k20 with vacuum booster.
I replaced all the brake lines and the proportioning valve and couldn’t get the brakes to ever firm up. I then replaced the master cylinder and it seems like the rear compartment (for the front brakes) is sucking in air. I have no leaks and no drips and of course, the master cylinder is brand new. We bench bled the master until there was no air, but when we start to try to bleed the brakes, it seems like the rear compartment is pulling in air. I linked a video below of what happens after you let off the brake pedal when we are trying to bleed. Both front and rear compartments will push a little fluid up, but when you let off the pedal the rear compartment bubbles.
Is this a bad master cylinder? Is it possible for the master to pull air bubbles all the way from the proportioning valve? We are stumped...
For additional confusion, we can bench bleed the master cylinder, and then put the master cylinder on the truck with the bench bleed hoses still in and then the same air problem occurs. I have a crazy theory that air is being pushed into the master cylinder in the rear through the vacuum booster because for some reason, the master cylinder is tight enough to the booster that when depressing the brakes air is pulled in, but when the brake pedal is released, the air can’t escape and gets driven into the master cylinder. I assume this shouldn’t be possible and would also be evidence that my brand new master cylinder is bad. Help!
