spedigo
- Dec 6, 2023
- texas
- Sam
- big10
I just replaced the master cylinder and the brake booster on my 79C 10. Afterwards I have a soft pedal or you might say it has a long travel before it engages near the bottom. Grab‘s fine at that point but definitely not like it was before.
Yes, I bench bled the new master cylinder and there did not seem to be any air pockets remaining.
I put a centering pin in the proportioning valve before beginning the swapand it did not move as I bled the lines. Did not seem to be any air pockets in any of the lines after bleeding them, either.
I put in a new JB5 power booster and measured the push rod length before I installed it and compared it with the old unit and it was within an eighth of an inch the same measurement.
my first thought is to adjust the pushrod length and make it a bit longer. One turn at a time, and seeing if that makes a difference.
any other thoughts or suggestions would be appreciated
