Quick brake system sanity check?
YakkoWarner
Central Texas
Wolf
R2500 Suburban
I've just started noticing a faint sinking of the brake pedal when sitting at a light. My suspicion is the master cylinder seals are starting to go and allowing fluid to blow by. I do not see any reduction of fluid level in the master, and do not see any leaks at any of the wheels or along the frame rails. Being a full float rear axle means I do not have the ability to pull the drums for a full rear inspection, that requires pulling the axles out. I just want to run this by others who know more than me before spending $$$ on a new master cylinder if that is unlikely to be the issue.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
If you're not losing fluid, backing plates aren't wet. Then it's most likely the master.
Could try bleeding all four corners, then see how it feels after that.
magnusvonjeff
