- Sep 3, 2024
- Nebraska
- Goober
- C15
IMO ...That is not a good thing..the calipers are connected to steel lines.
I guess I need to talk to the shop...The front wheels turn, there has to be a flexible connection somewhere usually a rubber hose, without a flexpoint the lines will break when you turn the front wheels.
It's steel lines to the frame (inside the frame rails), then a rubber hose to the caliper (outside the frame rails). In the back it's a rubber hose to the axle, then steel to the wheel cylinders. There has to be rubber between the frame and the calipers and the frame and the axle, otherwise the steel lines would bend immediately and break from suspension travel, leaving you without any braking whatsoever.I guess I need to talk to the shop...
and yes i was absolutely not thinking about that. just took the information i got for granted. feels kind of stupid
If your shop doesn't know this info,and already have the problem figured out,sounds like you need a different shop.Is this a legitimate, real shop with a credit card machine and employees?I guess I need to talk to the shop...
Agree can never say never, however I can't remember a master alone causing unequal side to side brake issues.Anything is possible but that is not a very plausible explanation. If one side works and the other has issues 99% it’s not the master cyl.
Nah it’s just learning bud. I thought you were working on this yourself.I guess I need to talk to the shop...
I didn’t see this post before my response above. Confirming what I and others said. There is no way to hook a solid steel line to a brake assembly (on the front brakes) not allowing for any flexing.the calipers are connected to steel lines.
When the brakes are locked what happens when bleeder is opened? To get anywhere with this need to follow suggestions and report back. Shouldn't be a hard problem to isolate.Another round of bleeding at the caliper bleeding screw shows the piston travels back and the wheel rotates until steping on the brake pedal again.
Fluid comes out and piston travels back. So i was toldWhen the brakes are locked what happens when bleeder is opened? To get anywhere with this need to follow suggestions and report back. Shouldn't be a hard problem to isolate.
