- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
they are both the same pump, why wouldnt it work lolI was able use my psc power steering pump with the 2500hd alternator bracket. The 8.1 oem power steering pump uses three bolts on the face and an extra bracket in the back. I swapped the studs and bracket from the oem pump onto the psc no problems. Also got the Sanderson bb-8 headers test fitted with no problems except the driver side knock sensor is real close to the headers.
But your pump is improved, it appears they put a bearing in the snout? Or is that just a bushing
