What years does this bezel fit?
Bloodhound1981
Law Enforcement
MA
Rusty
C-10
Trying to clear out extra parts and sell. What year does this gauge bezel fit? I assume by the large radio opening it's for 1988-91 one ton trucks and Blazer/Jimmy? Just want to make sure I list it accurately.
legopnuematic
Licensed Junk Dealer
MO
Spencer
I believe the din and a half started in 89?
So 89-91, don’t forget the suburbans.
xm20k
Girard, Ohio
No wiper switch cut out and the radio cut out suggests late 80s not sure what year others may have a better idea.
Moderator
Yep. '89-'91 Suburban, crew cab, and K5. And some cab&chassis trucks too.
Bloodhound1981
Law Enforcement
MA
Rusty
C-10
Thanks all!
Lightfoot
Hawaii
C10 Silverado
5.3 LS
This may be a late answer but that would fit both my ‘85 C10 and ‘86 K1500 (which I still need!).
nvrenuf
Mobile, Al.
It won’t look right unless you cut the dash to fit a bigger radio.
Lightfoot
Hawaii
C10 Silverado
5.3 LS
Oh yeah, that's a good idea!
Larry Sills
MS
Larry
1991, depending on Blazer, Suburban or 1987 R10 and C10 and earlier. Close inspection of rear probably shows Dremel cuts to enlarge radio opening.
Moderator
No, it is not modified. That is a molded radio opening and correct for '89-'91.
hauto85
