is the "Frostbite FB167 Aluminum Radiator, 4 Row, 1973-1991 Chevy/GMC Pickup" garbage? bbc c30 getting hot with ac on
winfred
port allen la
winfred
c30 v2500
What is your fan to shroud clearance like?
as it should be as it's all factory parts and not modified, motor mounts aren't sagging as the gap is even all the way around, i'd say it may be a little deep into the shroud, as you'd like it out of the back a little for radial ejection of the air, but big block is big block and it's using most of the room between the core and firewall, rad is pulled into the core support as well as i can considering how bad a square tank aluminum radiator fits stock mounts, i got creative with some urethane mounts and got it wedged in tight enough to not move
winfred
port allen la
winfred
c30 v2500
the answer sports fans is, yes, the fb167 frostbite is garbage, i replaced it with a standard plastic tank 2 row (2.25" core) big block replacement radiator and on a 10 mile drive with the ac on, towards the end after a while at 60mph it was regulating at 192 according to the holley display, and at the end of that drive i idled at the shop for a good while before it got to 215, engine would've probably barfed up a head gasket if allowed to idle that long before, this is with the stock condenser and no electric, plus it cooled down with a rev and the ac still on, i have a parallel flow unit that's going in and may or may not help with the heat load on the radiator, but will help the ac
best guess is the fact the FB uses 4 separate rows of tubes, the face tubes are in good air but they get progressively hotter deeper into the stack, normally thick cores will use deeper tubes, like the unit that replaced it is a 2 row/core, but they likely have the same or more area without the wasted space/air turbulence between the extra rows
not only does it stay cooler but the fan seems more responsive with access to better air flow
ill update this further once the condenser is swapped and i have the data for the longer and faster trip home, plus electric fan install (guess im putting that 73 grill i bought on the wall in my den, as there's no room between it and the condenser, maybe get the headlight pieces too and add lights :cool:)
now to see about the chances of getting my $500 back from speedway...........
winfred
port allen la
winfred
c30 v2500
ok, last friday my daily 91 v2500 squareburban's lr tire decided it didn't like having air in it after 9 years on the truck and 2-3 hours at the dealer/work and went flat, an inspection yielded many cracks but no punctures, so it's sidelined till i can afford to get it $1380 worth of more bfg's.....
in comes our hero the c30 to save the day, i swap in the new condenser and drove it home for the weekend, even without an electric its happy, hottest i saw was 208 after a slow bit of traffic and long light, dropped right down into the low 190s once i started moving and the fan clutch got some rpm, i get an electric on it and itll be solid, our ambient has been in the mid-upper 90s with all of the humidity here in armpit loserana, the modern condenser i think took a little more heat load off the radiator, it does blow nice and cold but my window seals are completely gone so it doesn't stand a chance of really cooling the cab, i've done the door seals just not the windows yet.
i didn't drive it this week as i don't know how much th400 i have left as it gets grumpy and ceases using first gear once fully up to temp, but it got 100 miles or more over sat-sun, so ill move forward with the 4l80e swap sooner than later, ill do a build thread once i get further along, hoping the OD, 4 actual gears, and lock up help the 5.5mpg i calculated for its first mostly on the road driving tank of fuel (it did have the extended high idle cooling system and ac stress testing on that tank, so that didn't help)
looking in my crap i found that i bought the radiator from carpart.com (and not speedway, many things did come from speedway so i remembered that wrong) and it was dropped shipped from holley, so i fired off an email to holley that was similar to the info part of my first post in this thread, after the best part of a week i get a reply that is a bit confusing
"something is missing from the equation there, the fb167 is a 4-row with 11/16" tubes, unless the one that was put in there was a 1" 4 row which is a rarity"
that was the whole response, kind've reminds me of dealing with GM TAC (if you know you know, dealer tech things) they cherry pick an irrelevant and or unrelated to the task at hand speck of your 5 paragraph explanation and that is the one comment you get from them.
i replied without my usual sarcasm and irritation for useless tech line chair holderdowners on monday and as of yet, no response, guess ill go crap all over it in the reviews with facts and findings and see if anything pops to the surface among the glowing reviews it has.......
i'm not mad, just annoyed.... HA
winfred
port allen la
winfred
c30 v2500
welp, that plastic jobbie started dripping from the bottom of the right tank at the core crimp, this was the "agility" brand that on rockauto has a heart by it, got mine from amazon for $80 less than RA for the same unit, was a bit out of the normal return window but as it was leaking the guy authorized a return, i replaced it with "
730 Radiator for Chevy Blazer/C10/C15/C20/C30 Pickup/Suburban 1973-1986* 28 3/8 x 19 7/16 x 2 3/16" core, w/ TOC, no EOC "​
this one has shiny plastic tanks instead of the satin looking ones fwiw, an even thicker core, and slightly less dense core fins, was the same $140ish, i picked it by the fastest listed delivery as they're all chineseum in a crappy picture, and i needed the box to return the leaky one before that return window closed in a week.
lucked out and it so far seems to be even further ahead of that garbage frostbite than the agility, took the truck to lunch (i don't drive it much as the th400 is about the **** the bed and i haven't had time to start installing the 4l80e thats been in my way a year) and its first drive since the most recent radiator swap, fan clutch kicked in at 193 on interstate at 65mph and off at 189, the 20-25mph mile though the neighborhood to the dealer i work at it was 185-187, so its running 5-10ish under what the agility was under the same trip
am i here to crap on agility? not really, this ones failure is just a data point among many, frostbite can have all of that heat screw those bastards, just another bump in the road and figured id cast the info up here general consumption for what its worth, the ramblings of a grumpy ol fart gm tech letting a fat burger settle in before going to go work on this turd new duramax
I've gotta say, I know way more guys that have issues with their aluminum rads than I do guys that use plastic/aluminum ones. I run Spectra rads in all my stuff, just OE replacements with plastic tanks and have never had an issue. The one in my '85 is 6yrs old and still rocking right along. Best part is, if I do have an issue, it's a quick and easy replacement unlike so many of the aftermarket aluminum ones
winfred
port allen la
winfred
c30 v2500
i wasn't going for the bling factor with a fab'd radiator, i legit fell for the hype of it being this huge badass radiator, as its the fires of hell here in south loserana and i despise overheating when it can be prevented, so now have a quasi useless $500 hunk of aluminum in my way, was thinking i might be able to use it for my down the road house generator project, it couldn't keep a 454 cool but it probably can keep a 2.5 5 banger mercedes diesel cool, let it swing an inexpensive 20-25-30kw head (depending how big/small the next house is) enough to run the whole thing at full power with some head space, then calculate a couple weeks of diesel..... ride into hurricane season like a boss
MoGold
