Wiring something for dual "activators"???
usar17
PA
K20 Silverado
TBI350/700r4/NP208
So I'm planning on installing some additional lighting on the rear of my truck to aid in backing up. My original game plan was to cut the wire for the reverse lights at the fire wall and install a relay so that the shifter is the switch and run a power from the battery to the relay to support the added lights.
But then I got thinking. Would be nice to have an override switch to activate the rear lights whenever I'm working behind the truck. so how would I wire it up to activate the rear lights by either the gear shifter or a toggle switch?
Wire the lights to 2 relays. One switched and the other triggered off the reverse light signal.
Sent from my iPod touch 4th Gen using Tapatalk
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Thats the only thing I could think of. I didn't know if there was a simpler way or some electronic device I haven't heard of yet lol.
Sent from my SCH-I545 using Tapatalk
Yep, Listen to PawPaw, he just wired a 12v cam himself in his Burbie.
I have a relay controlling the factory and accessory backup lights, and I plan to install an interrupt switch so I can turn the backup lights off when I am backing the boat up to the house late at night so I can stop pissing the neighbors off lol.
You're to damn kind. I'd be installing a Back Up Audible. Beep Beep Beep Beep, get the **** outta the way I'm backing up my boat !!! :happy175:
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Ya Id install a horn wired to a flasher controller lol
Think of it this way, we got stealth mode for when we backup to Old77's garage with our self tappers and donated parts lol.
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Haha Haha
Yep, we might need that. So we'll have to put a relay on our relays. :insane:
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Couldn't you run two 12v+, one from the shifter and one from the added switch, to the relay with the common ground?
Then when either is activated, the reverse lights will be activated. It would eliminate the added cost of a second relay.
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Because wouldn't that back feed the other line when one is active
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Unless they make relays that can handle 2 switch lines
I'm not sure LOL
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
It would backfeed unless you had a diode on each line to prevent it.
But would backfeed really matter in this case since one or both lines would be open at any given time? Plus they're only basic switches instead of a fancy electronic component
nathanjohnson85
