Where to get these parts....
R8rPhan
California
Mark
1973 (1979?)
C10 long bed (Frankenstein truck)
73 Chevy C10 (with A/C)
I appear to be missing the two Heat/AC distribution plenums highlighted in red in the picture below... Also missing whatever valve or whatever that is that is coming out of the bottom of the plenum on the left (shown exploded)
Any idea who might sell/source these parts? :shrug:
Swims350
Logan WV
none
as soon as I can take mine out I'd sell it. I've got complete ac and the outside firewall box fell apart going to go heat only. I should have those pieces I'll have to check.
Craig 85
Nashville, TN
454/TH-400/NP205
You can get the left side plenum from most square body parts suppliers for around $30. It will not have the foot cooler though. You will probably have to get the center section and floor heat diverter from a donor truck. I looked in the 6 catalogs I have and no one carries those parts.
R8rPhan
California
Mark
1973 (1979?)
The only part I've been able to find is for non AC versions, and it comes out from the main fan/diverter box (LMC has it for 30 bucks).. There's a valve of some kind in that port on A/C versions... The one I have comes out of the other plenum box of the two that I highlighted in red... The Non A/C one comes out of left the end of the box behind that that box attaches to the front of...
If you have seen the one for the A/C version anywhere, please let me know where...
R8rPhan
California
Mark
1973 (1979?)
Appreciate it!
I've asked a couple friends around here to check their donor truck piles as well...
R8rPhan
California
Mark
1973 (1979?)
Are there any special 'necessary' valves or whatever in the parts I need?
I'm wondering why I couldn't just build a plenum myself that connects to the upper plenum, and then use regular round duct to replace the piece on the left?
Anyone done this (surely some have), and have pictures and or a link to a thread about it?
Thanks,
Mark
:cheers:
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
I had to use some ingenuity and some aluminum flex duct. I found a piece at Home Depot. It works for now. The tricky part is stretching it out and then squashing it enough to fit up under the steering column.
yevgenievich
Viktor
sad
very sad
less sad
I might havr those pieces from a donor truck. Can check over the weekend
74 Shortbed
I may have one too??.
R8rPhan
California
Mark
1973 (1979?)
Can you guys post pictures of the parts you have, and what it might cost to get them in my hands?
darrel
