Wheel offset
Mattrob
Sierra
Looking for a replacement wheel for my 77 GMC Sierra 25. Looking to put on a set of factory wheels from 2003 Chevy HD. 8x6.5", Offset - 28mm, Hub Bore - 116.7mm.
Will these fit without issue? Not sure about offset.
Thank you.
Auburn, Washington
I’ve seen them on squares before. So presumably they fit. They do have more positive offset than typical wheels for squares though.
What you wrote is neg offset but I’m pretty certain those oe wheels have a healthy positive offset (rim sits further in than out from the hub face)
Soundmound
North Central Washington
Dave
Scottsdale
It's my experience that most OE wheels are either 0 offset or slightly positive. I need a set of -12 for my '02 after the lift kit. Well, need is an overstatement, it would only really add about an inch of track width at best and I don't see that making a huge difference.
The newer wheels do have a bit more backspacing, but they do fit.
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
My K30 had them when I bought it. Tight fit with a Dana 60, but they do fit. Tires were 265/75R16.
wilson79
