What should I do with this toolbox?
bigcountry78
Hickory, North Carolina
James
K10 Custom Deluxe
I kind of inherited this box from my wife’s grandfather, but I’m not sure what to do with it. It’s a really nice Mac box, and it’s just been sitting empty since I got it. I have most of my tools in a big craftsman box, so what should I put in this one? It’s too big/heavy to be a portable setup.
nvrenuf
Mobile, Al.
I wish you were closer, I’d love a top box like that. When I first started buying tools I bought a top and bottom like that but a couple of years later I traded the top for more tools, I figured a full(ish) bottom was better than a mostly empty set. :crazy:
Camar068
Air Force Supporting Member
10 yrs Air Force
make it the electrical tools box, impact sockets, or specialty tools rarely used. Or for household plumbing tools.
319E
Northern Michigan
E
D30
6.2L
Make it a mobile tool chest by building a low platform beneath it and installing larger (6") swiveling pneumatic tires so you can roll it around your unpaved garage and or driveway to whatever you're working on. Keep a low center of gravity so it cannot tip, and you can probably sit on it when the lid is closed.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Being a shade-tree machinist I see that box as similar to one of my Kennedy machinist's box. Maybe dedicate it to your taps, dies, drills, measuring instruments, Machinery's Handbook etc.
Or find a similar specialization like body and fender and paint tools and supplies. On a smaller scale, I use tackle boxes for certain specialty things like all my paints and tools from when I had time to build models. I use one for my electrical work that has all the crimpers, heat shrink and terminals for that kind of thing. So maybe it's a big metal tackle box for some specialized work. Or bolt it into your squarebody and use it to jumble your tools when you go over bumps.
Sad Sack
Nebraska
Goober
C15
Solved:
goldpack
Adirondacks, NY
Donnie
GMC C2500 Camper Spec.
350 with 350 3 speed
reminds that it seems to be missing its bottom half,....or it spent its life on a work bench.
if not automotive tools....
you could put things to fix homes with:
wood working/ plumbing/ electrical tools in it. (so you don't have to go digging for such things in other tool boxes.)
legopnuematic
Licensed Junk Dealer
MO
Spencer
I like tools and toolboxes.
Up at my shop I have six tool box “stations” (some are just bottoms, some top and bottom, riser top, top riser and bottoms).
-My main 72” box general mechanic tools, some specialty stuff.
-5 drawer tech cart, another set of mechanic tools
-Kennedy 8 drawer top and riser, metrology and some mill tooling.
-Craftsman bottom box, mill tooling, endmills, reamers, drill, etc, etc.
-Old Homak top and bottom box, body and paint tools, welding, and fabrication.
-Kennedy bottom/riser, Huot top box, electrical, specialty, gauges, test equipment, some more measuring tools, files, etc.
I like to break stuff up by the area it’s in and keeping proximity to where the contents are most likely to be used.
For your box, a good use case could be hardware storage or as mentioned, specialty stuff, or so on. You can also integrate it into a bench or work area as a ‘lower’ box. Toolboxes are a relatively cheap and easy way to integrate drawers into something.
Keith Seymore
Motor City
Keith Seymore
4.3L
I find that no matter what I am working on it is going to require every tool I own.
I just get them all out and start from there.
K
legopnuematic
MO
Spencer
K
I call those garage sale jobs…
Just need the sign- “this table $1.00/ea”
Old Guy Bill
KY
Bill
I had two similar to that, one I hauled into where I work part time and set it up... I'll leave it there when I retire. The other was in worse shape, I "donated" it to the local thrift shop.. meaning I left it by their dumpster. :)
Original
