hoagster
California
K10, 1500
5.3l
Started in on the cab, after this it will be wiring and firewall pad, haven't decided on the A/C yet OEM or other!
Still need to work on the manual shifting but need to prep the cab first so I can install pedals and steering column.
chevelle427
Alabama
Lee
Just figuring out how to post here
1974 c10 anyone know where the yellow taillight wire gets its power from.
My dash lights are gone
Power to the yellow and green gone
I have 2 hot sites on dash plug but the circuit they touch is not hot.
Any idea
Changed out light switch no difference
Have another dash cluster coming Wednesday hope it works
Backyard
Ontario
Nathan
Hood sits down fine. You can see in thr pictures I had to cut the one end where the spring would attach so it would clear the hood pistons. I used 23" long pistons with a 9 inch stroke 100lb.
All that being said It does feel a but tough at first to close but not enough to do any damage to the hood. I am using old wore out hood hinges that i do plan on replacing I would imagine that would make it a bit easier to close
I am happy with thr results so far.
Camar068
10 yrs Air Force
Got the lens installed on the sun visor. I put black silicon under them to keep moisture away from the leds.
Backyard
Ontario
Nathan
Short video attached of the hood pistons/ struts open/ close
Subscribe and it will give me all more reason to share on you tube
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Subscribe and it will give me all more reason to share on you tube my projects and fab
That's awesome!! I want to do that with my international scout! It's just about out of arms reach lol
Doppleganger
OH-MI: Just like it sounds
Had multiple delays to get my cab in paint so been tweaking this idea of using a Benz Sprinter van's tire carrier for my spare. Had the tire mounted to the rim for accurate size/weight. All the chains is how its suspended while making a jig that centers it where it needs to be. The class 5 hitch says I need to relocate the spare, which isn't happening. I trimmed off the most forward (4th) underside mount hole on it (which aligned with nothing but air) and am adding 3/4" steel plates that will attach it to the sides of the frame with (8) 5/8" Grade 8 bolts. I sent a drawing to Draw Tite's tech dept to see how they thought it would fare strength wise. Removing that extension allows the full size (33") tire to just fit. No room to 'spare'.
The small rear brake line bracket has two 5/16 holes that will work perfectly for a 1/4 thick plate extension to the front hinges. I had a new brake flex line made with a 90* on one end so as not to rub the tire.
The last pic is the back of the carrier. Been thinking of something as fancy as a gate latch (on both sides) to hold it up, or perhaps something as simple as 2 hooks with a turn buckle in the middle. Dunno. Carrier is a 1/2" bar and most latches are 3/8, so not sure if they even make one that would work. Carrier brackets will be powder coated before permanently moving in.
Ajax19
Socal
Ajax
I'm surprised you don't have ethanol free fuel at various gas stations due to the amount of classic cars CA has! Go to this website posted below. Here people list what stations has ethanol free fuel.
I'll check it out I have already been running the 87 octane without issues (after upgraded accelerator pump to viton) I keep the timing really conservative whopping 6-8°btdc(can't remember now stock is 4°) driving and hauling good went and got another yard of topsoil for the garden yesterday I also wired up the fogs last week hope everyone had a good 4th
quick video accelerating with 2-3000 lbs of dirt in the back
vr1967
Mississippi
Virgil
k1500
6.2L turbo
Looks good.
Doing something very similar on my 84 k1500, using the spare winch and frame hanger from an 04 Dodge Ram. Got it mocked up close, just need to pull the bed again to double check and finalize position
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
Wow
Tinker
LI, NY
Greg
C15
Installed the powder coated wheel wells. Looks much better under the hood now.
Garcjay
