80BrownK10
Greenwood, SC
Nate
The big annual six flags swap meet/garage sale was today.
Saw this 79, which I saw back in September of 2018 (2nd picture)
My loot, got a decent 73-74 chevy grille, a bunch of metallic stickers, spirit of 76 stapler, a GMC badge from a medium duty truck, 79 licence plate
Love that green.
Big Chip
Michigan
Kevin
C35
4 or 5. Just like locking my keys in it, about 10 or 15
I locked my keys in my 86 once at a car show. These two cats come by and claim they can get in, no problem. They took the wire off their master cylinder that holds the cover on and and proceeded to insert it in the back lower corner of the vent window, hook the lever, pull it out which pushed the lock button in and then just twisted it to unlock the vent window. I’m sure they were pros if you know what I’m saying? I had to do it one other time and it worked perfectly.
78C10BigTen
pennsylvannia
C10 BIG TEN
Never heard that trick! I put a hidden key box on mine
  • Like
Reactions: WFO
Moderator
There's been a few times I've got myself in with my own radio antenna. Obviously that doesn't work with most squarebodies though.
78C10BigTen
pennsylvannia
C10 BIG TEN
Power window versions ?
I guess they would have an extra hole for the switch but not one for the window crank ?
What color are the panels?
Oh, yeah - are there speed nuts on the piece ?
Heres what ive got
Poppy 87
Bloomingdale GA
R10 Silverado
The latch on my sliding rear window has been broken for years! Just got to climb my big ole body into the bed and reach through to unlock her. I will fix this when I get her painted. Any thoughts on sliding rear window versus solid? Haven't decided yet
Sent from my XT1254 using Tapatalk
78C10BigTen
pennsylvannia
C10 BIG TEN
I couldnt live wihout my slider. Second favorite air source other then the vent window
Big Chip
Michigan
Kevin
C35
I’m not sure how to unlatched them if that’s what you’re asking. Personally I’m going to put a solid window in mine because I’m tired of my slider leaking.
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
Where is it leaking from?
350 w/203
Weather was nice, ground was dry enough to put some cardboard down so I finally installed new KYB's on the corners yesterday! First new shocks in about 35 years. No test drive yet. I'm sore as all get-out but it was FUN and it felt good.
Unfortunately I found that I have to remove the hood, fenders, wheel liners to align the doors.
And rain in the forecast every day this week. Chippin' away at the stone!
ShortBus
Florida
Charles
V20
350tbi
My 87 is pretty much all original. Everything works, mostly, but its all OLD. Been replacing stuff as I can afford to. I have a few vehicles I'm always having to work on so I have to divide the time and money up between them all.
I've done the throttle body, o2 sensor, spark plugs, brake circuit from booster to the prop valve, clutch slave and line, and lots more.
The brake stuff and o2/plugs were last week. I've got a new throttle cable ordered at the local parts store. Picking it up this am and hopefully get it on this afternoon.
Anything special I should know or is it pretty straightforward? Looks pretty simple.
that_orange_c10
