- Aug 7, 2016
- Weiser Idaho
- Perry
- K20-K10
@bucket I was just shocked that someone would spend that much on bondo
So useless info from this (me) old timer. The fender washers on the first squares, 1973, were "U" shaped with no tab. Following year, "1974" the "U" shaped washers had the tab. Much easier to deal with, as you could tape 2 or 3 together for a test fit. Slide them out and add or subtract as needed.The AMD fender fits and lines up very nicely however they need to add the little tabs to their shims the little squares are a PITA.
I had a 69 C10 once upon a time that sat weird, and launched weird, no matter what I did, new springs, swapped side to side, measured to death...I once saw an '83 Trans Am in the junkyard that someone tried to make look like the Batmobile. It was poorly done (of course) long ago and the bondo was cracking off of rusty metal all over. The mud was 1" thick in a lot of areas. There must have been at least 10 gallons just in the rear of the car.
