Strick
Dunn, NC
Harold
C20 Crew
I was finally able to work on my 78 after telling everyone else “NO”! The timing needs a bit of adjusting & may need to run back through the valves. It runs & sounds great even before the fine tuning. I have brakes but no power steering yet but that is on the way. The wiring was a mess but it now starts with the key & the clutch must be pressed! The horn & reverse lights even work…I can’t believe it. Working on the facelift now with the students.
Hapnin’ Soon!
The Right side of Washington
Hapnin’ Soon!
The ole new badge on an old truck! Looks familiar…
hoagster
Air Force Supporting Member
California
K10, 1500
5.3l
Hapnin’ Soon!
That's awesome your able to do that need more schools to adopt having classes like this back!!
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
I was driving away from the local Tractor Supply in Kelso, WA yesterday and their school is just behind the shopping center. Went right instead of left and out in front of their fabrication/automotive sciences building, some kids had an early 80's square out front, idling with a mild but distinct lope to it. Made me feel good seeing and hearing that. I wanted to stop and chat, but in this day and age, random old men chatting up kids about anything isn't a good look so I just left with my best wishes for their futures.
Sad Sack
Nebraska
Goober
C15
Especially if you're driving a non-descript white van with a ski mask on.
CountKrunk
SW VA
Count
C20 Custom Deluxe 3+3
v8 350
I hooked up a one way diode on the alt control wires to stop the backfeed.
I can leave the positive hooked up now.
Camar068
10 yrs Air Force
curious if your headlight buzzer (IGN off) works after doing so?
The alternator has diodes in it. Sounds like you possibly need an alternator.
Check for A/C voltage at the alternator,there shouldn't be any. If there is your new alternator has a bad diode,and they charge fine with a bad diode,the normal symptom is battery draining when parked. Why did you go 1 wire?With 1 wire you lose your voltage sensing wire, your alternator loses the ability to charge in accordance with system demands.
CountKrunk
SW VA
Count
v8 350
Check for A/C voltage at the alternator,there shouldn't be any. If their is your new alternator has a bad diode,and they charge fine with a bad diode,the normal symptom is battery draining when parked. Why did you go 1 wire?When you lose your voltage sensing wire your alternator loses the ability to charge in accordance with system demands.
This is the one i have.
It says one wire but it can run that way or with the two wires in a clip as well.
I have it hooked up with the clip to do what you described.
With key off i was getting backfeed through wire 1 of the two.
gilby959798
CLT NC
GMC K25 Camper Special
Got the transfer case back because the old man came down. Tested the bushing and Success! I should have a 4wd indicator on the dash in low and high.
blue10
