ChuckN
Bellinham, WA
Chad
What location did you put the gauge?
The old CD player that came with the truck was nonfunctional, and the bezel was already hacked up because of it, so I just grabbed a piece of plastic from the hardware store and cut it to cover that area. I used a hole saw to cut two spots to mount the AFR and vacuum gauges. A better place would be high mounted at the air conditioning vent, but I haven’t deleted all that stuff yet.
ChuckN
Bellinham, WA
Chad
Brought a laptop with a DVD drive to the shop and some shows/movies to rewatch while I worked
Got the back of the cab hit with some high build epoxy primer.
Looks great!
I do the same with movies in the garage- an old favorite is Young Frankenstein just because I love the quotes.
Camar068
Air Force Supporting Member
Kentucky
10 yrs Air Force
Don't think I shared the new washer fluid jug. Need to reconfigure the mount, but it's in there and functional. Went thru 3 plastic tanks....all cracked in the same spot.
82sbshortbed
Why like that?
SE Texas
Doug
1500 shortbed, 1500 longbed
Got the grill back in and the Chevrolet led mounted and hooked up. Looks pretty good if I do say so myself. Hooked it to the running lights. I'll take some more when it gets dark.
82sbshortbed
Why like that?
SE Texas
Doug
Gave him a good washin'. I'll be taking him to work tomorrow. So gotta be clean.
Spider
Montana
Craig
GMC and Chevy v2500 suburbans
5.7 tbi, 6.0
Went and played a little bit in the snow. Camped out in the burb for the first time. Luxury.
Also had dual exhaust installed. Sounds good.
brooksman9
Olive Branch, MS
Patrick
Silverado & Custom Deluxe
350 & 305
Fixed an oil leak today from yesterday's test drive. See if you can figure out where.
legopnuematic
Licensed Junk Dealer
MO
Spencer
The bolt on the front of the block looks awful fresh with some sealer…
Is the bottom fuel pump plate bolt broken off?
brooksman9
Olive Branch, MS
Patrick
350 & 305
Yep. Bolt/plug for holding the fuel pump rod in place during installation missing. Had the same issue on one of my Camaros years ago. Lots of oil (I say lots, probably not that much) on the steering linkage just below there. Only comes out while driving. Perhaps a little spirited driving. I know I didn't take anything out of there when the engine was out. Had to have been like that.
Joestreml
