Tires - 245/75/16 or 265/75/16?
Mattchu60
Iowa
Hey everyone,
Now I am looking at Tires. Probably going with either BFG A/Ts or Rugged Terrains. Looking at either 245/75/16 or 265/75/16's.
Anyone have input on either size? My understandig is that the 245's are around 31" and the 265's are around 32" tall.
Any picutres of either?
Jake_S
Charlotte, NC
350/SM465/NP208
245/75/16's are equivalent to 31x10 and 265/75/16's are equivalent to a tall 32x11.
Without more info regarding your truck input will be very limited.
Jake
Mattchu60
Iowa
Sorry - more info - going on a 1987 3/4 ton. No lift, stock height.
Go with the 265's, they are close in height to the stock 235/85's.
77 K20
Montana
K20 5" lift
HT383 fuel injected
Yep- what bucket says. Also it depends on how much you stock suspension has settled. Mine settled quite a bit.... but here it is with the 235/85's on it:
picture.php
And this was with the 265/75's on it. Same height- just a bit wider. I like the way the 265's ride. Same load range E, but they soak up potholes and bumps better. Are you going to get new wheels? Or how wide are your current ones? My stock steel wheels were only 6" wide and that was too narrow for the 265's. Ended up buying some black steel wheels in 8" wide. Usually the recommended wheel width is 7"-8" for them.
picture.php
picture.php
Mattchu60
Iowa
Thanks for the pictures - do you have any issues with the wheels rubbing while turning?
I am going to be getting new wheels - do you remember what the offset is on the black ones you put on?
77 K20
Montana
K20 5" lift
HT383 fuel injected
Nope- they didn't rub. I did put a lift on it not long after this as I found I had some damage done to the front leaf spring, the shock mount, and the bump stop bracket. (Didn't see a massive hole in the shade on a forest service road).
I bought mine from discounttiredirect.com and they are Unique model 297s. 16x8, 0mm offset, 4.5" of backspace. $99 each. They are made by Cragar. Cragar does have some that look almost the same, but the holes are slightly larger. Cragar calls them the black soft 8. Same price and specs.
Jake_S
Charlotte, NC
350/SM465/NP208
77K20 has a good point. The stock steel wheels (16x6.5) are really to narrow for 265/75's, though there are people with the newer 16x6.5 alloys running 285/75's without issue. I personally wouldn't do it.
Jake
Jake
It won't hurt anything at all. Several times I've run wide tires on skinny rims, never any problems. Tires have a recommended rim width, it's not required. Although a skinny tire on a wide rim can cause troubles.
77 K20
Montana
K20 5" lift
HT383 fuel injected
More than anything it depends on the tire shop that will be mounting them. At least in my area so many are afraid of getting sued they go by whatever book they have. If the load rating, or wheel width, or the speed rating is off they will not install them. I've even asked if I could just pay them cash, not get a receipt, or even sign a waver. They said no way.
The only issue I have ever seen with running a rim that is on the narrow side is it can wear the middle of the tire out quicker- especially if you are not running weight in the back of the truck all the time.
Jake_S
Charlotte, NC
350/SM465/NP208
I personally have issues with wide tires and skinny rims. I feel that having the sidewall bulged out too far is asking for debris damage, either on the trail or on the road.
Just my $.02
Jake
Jake_S
Charlotte, NC
350/SM465/NP208
My 84 K20 needs tires, but I am looking for a set of these wheels before I get new tires.
17x7.5 8 lug steelies from Dodge Ram (2003-2012)
I like the way steel wheels look on the square's but Chevy did not provide us with much choice with the 8 lugs.
Jake
Mattchu60
Iowa
Hey Jake,
Not sure if you knew or not, but the GMT400 3/4 trucks came with steel wheels. They sort of look like a ralley wheel, but they are not. Just another option to consider.
Jake_S
Charlotte, NC
350/SM465/NP208
Hey Jake,
Most of GM's 8 lug steelies are 6.5" wide, which is the same as teh square 8 lug steelies.
Jake
77 K20
Montana
K20 5" lift
HT383 fuel injected
Hey Jake,
aaron06
