RV cam & 502 HO head compatibility
80goldenburb
LV,LV Raider Nation capital
Nico
Suburban C20
'68 cad 472
When i bought my C20 Burb it came with a 502 HO (confused block casting 10237300) which came up as a Gen VI. I call this "confused" as this is NOT a VI but actually a Gen V (no mech pump provision and flat tappet cam). The 502 has since been replaced by a low mileage (37k) '78 RV 454 due to multiple spun bearings that developed in late sept 2016. The heads were still good and I decided to keep them (casting #1497088) when i sold the block after coming across a few Ebay ads with big price tag ($900+, i only paid $670 for the entire truck!). I would like to eventually swap these 088's in place of the 781's that are on it now. What are the differences betwen MK IV RV cam and Gen V 502 cam ?
vkh
Western Montana
Var
C2500
Aren't those rectangular port heads? If so I'd suggest sticking with your 781s. Rectangular ports will kill your low end torque. Less your gonna build an RPM screamer I think oval ports will give you the best overall performance. Also it sounds like you may have to drill holes to run gen 5 heads on a mark 4, though that's just from a quick Google, so take it at what it's worth.
74 Shortbed
Yep, rectangular heads, 781's are ovals best factory heads for the street, put the big valves in and do a clean up and it'll be a torque monster..
80goldenburb
Nico
Suburban C20
'68 cad 472
Drilling isnt mandatory, its an option for extra cooling capacity of the Gen V and VI blocks. I would just need MK IV head gaskets and they would bolt right up.
Gurn
