Removing transmission fluid from the driveway
one4fun
Portland, oregon
chris
The clamp on the hose of the transmission cooler came loose and my K10 barfed 5 quarts of transmission fluid onto my driveway yesterday morning. :mad:
Recommendations for effective ways to remove this big of a stain? It is about 3 feet wide and 12 feet long.
MadOgre
NA
NA
NA
NA
NA
start with some floor dry
then some cleaning agent and then pressure wash it
Look up your local concrete accessory dealer for options. Best I know of is L & M Citrex but it aint cheap.
kdo58
Puyallup wa.
k5
super purple cleaner a gallon jug from walmart, let it set for a while, pressure wash it, and if that not good enough muratic acid, nasty stuff.
Carb'ed Vortec 350
Draw an outline of a person, and let people know the poor ****** tried to EFF with my truck and this is where he bled out...lol...
77 K20
Montana
K20 5" lift
HT383 fuel injected
Kick dirt or use kitty litter on it first to soak up as much as possible first. Let it sit overnight if possible. Then sweep it off. Then pour dawn dish wash soap or simple green on it. Scrub in with a brush. Let sit. Rinse with hot water or a hot water pressure washer.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Good suggestion, just be sure if you use the muratic acid to stand upwind and wet down the area around the stain first with water.
You probably don't own one, but I've found my HF pot sandblaster works really well for oil and rust stains on the driveway. It would take a while to do a large spill but it makes the concrete look like new. Just don't use a sandblaster on a blacktop driveway.
friscobob
Sutherlin Oregon
Bob
C 10
TSP, buy it at your hardware store, use as directed.
Bob
scottybaccus
Central Texas
Scotty
GMC R1500
Bury it under kitty litter for a week. It will be like it never happened.
PapaBear8486
