Removing emissions......what is this???
Before I got headers, I took off the manifold, cut out that valve and had the holes brazed (closed).
Truck ran much happier. At the time I kept the heat riser tube to the air cleaner.
Ken B
indiana
ken
thank you for that honest simple description that does clear it up.
Well, the valve had rusted shut and I couldn't afford headers at the time.
If it had rusted in the open position . . . the engine could still breathe. It was like my engine stifled a continuous sneeze!
Ken B
indiana
ken
I am going to have to figure out what to do when I get ready to swap the engine from my donor to my project. ...factory exhaust or headers....
SASKCHEYENNE75
Saskatchewan, Canada
Jarod
350 4bbl
So here is my progress over the weekend...
Started by removing the smog pump. I noticed there was no pulley so at some point in its life it had been bypassed however the big ugly hoses and metal tubing attached to the manifold were still all there. I cut off each metal tube (with a small cutting wheel on my drill) about 1" away from the plug where it attaches to the manifold and removed them. The plugs actually turned out quite easily too...a little WD40 and out they came. I then used 1/4" brass plugs with high temp thread lock on them and screwed into the 8 holes left in the manifold. Seemed to hold nice and tight.
Next I unhooked the rubber hose at the front (top?) of the EGR valve, followed the hose to a where it connects to a fitting on top the thermostat housing, disconnected from there and also to where it T'd off to the front of the Rochester Quadrajet carb. I used rubber vacuum covers (plugs) to block both lines after being disconnected and also the one on the EGR valve. I don't have a block off plate for the EGR yet so I left it bolted on to the intake.....just unhooked it.
SO HERE IS MY NEXT PROBLEM (Dont you love old trucks??)
While cutting off the smog pump metal tubing I accidentally cut 3/4's of the way through a spark plug wire. Well guess it's time for a new set of wires!! Off to the store I go and buy a set of Blue Streak Performance plug wires and 8 AC Delco R45TS plugs (might as well change those too right??) I come home, remove the wires and carefully install the new ones in the correct spots (double and triple checked), installed the new plugs.
While I had the air cleaner assembly off doing all this work I figured I might as well clean up the Carb too as it was all grungy and covered in old dirt and oil. Took a can of carb cleaner and sprayed the hell out of it, let it sit, sprayed more, wiped...repeat repeat. Carb all nice and clean looking!
Put the air cleaner back together and time to fire it up. Started and died, started again and died, started again and ran smooth at high idle (about -10 degrees Celsius in the garage). Idle started to come down as it warmed up then started chugging and died. Stared it again and died shortly after. Did this about ten times then tried to start it and nothing. No click, no fan, no lights. Figured maybe I ran the battery dead so hooked up the charger for a couple hours and went inside to warm up.
Came back out and dead...no power anywhere. Wiggled the battery cables at the posts and nothing. Ignition on or off makes no difference. No headlights nothing.
SO (sorry for the long winded post!!).............
1) Gotta fix the electrical issue....maybe dead battery cable? Maybe fusible link?
2) Once that is fixed gotta get it running smooth again......did I create a vacuum leak while cleaning the carb?? Is the gap in the new plugs wrong? (I didn't gap them as I thought they were pre-gapped to .045......my bad should've double checked!)
3) Did unhooking the EGR cause it to run crappy at idle (remember it ran fine before doing any of this stuff and then ran fine at high idle but died as soon as idle started to slow down as it warmed up)
GRRRRRRR
SASKCHEYENNE75
Jarod
350 4bbl
Here is the Carb Number for reference
Exhaust plugs I used in the manifold
Main power Buss at firewall
Ken B
indiana
ken
Damn that's a crappy sequence of events.
I like the brass plugs!
SASKCHEYENNE75
Jarod
350 4bbl
It sure is....like the saying goes "when it rains it pours!"
But I guess one thing at a time. Its way to cold out to work on it....minus 32 Celsius here today!
Read what I said about EGR. It is inop at idle and inop under load.
Octane
Atlanta
Eddie
Make sure the disconnected egr is not stuck open as that would be a massive vacuum leak
EGR should default to closed with no vacuum applied.
Octane
Atlanta
Eddie
It should but when that thing gets corroded it may not. My 77 k10 doesnt have any emissions on it and never has thank goodness.
Can't hurt to check, but if it wasn't stuck open before he disconnected the hose.I can't see how it got opened. Did you by any chance do something like reach under with your fingers and move the valve pintle?
SASKCHEYENNE75
Jarod
350 4bbl
So I should be getting a block off plate and eliminating it completely therefore no risk of it being stuck.
mmeade
