Pulling the 1986 5.7 Broken Cam
RawkerStatus
California
Angel
Suburban K20
Spent yesterday and today pulling the engine. Got stuck for an hour or so on the 2 right hand bell housing bolts. Should be out tomorrow if not then Friday.
Moderator
Are they stuck, or just working around the dipstick tube and the t-case support rod?
RawkerStatus
California
Angel
Suburban K20
That one was giving me trouble. Ended up using a wobble and extensions. The top right I unbolted the trans and lifted it up to tilt the engine forward. Open end wrench was rounding the bolt off, couldn't fit a 1/4 ratchet, 3/8s barely fit and took all my finger strength to break it loose. But the lines i forgot about was the trans lines bolted to the front and the heat shield bolt on the left side.
RawkerStatus
California
Angel
Suburban K20
Got the engine on the stand. Pulled the intake manifold. Found bank 2 rear water jacket almost completely clogged. Cylinder 5 push rod bent.
RawkerStatus
California
Angel
Suburban K20
Mhm... I think the block is toast.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Time for a big block...
Moderator
Impressive carnage!
SquareRoot
Those front Dana 60 hubcaps probably caused this whole mess. You should remove them and sell them to me.
RawkerStatus
California
Angel
Suburban K20
Donor 350 is stripped down, cleaned, ready for paint. I'm thinking machine gray for the block not sure about the valve covers.
Moderator
Machine gray? Like an industrial engine?
Imho, stock black paint, GM corporate blue, or good 'ol Chevy Orange.
Although @Swims350 recently painted his engine a gold color and that looked pretty cool.
RawkerStatus
California
Angel
Suburban K20
I was thinking this. But I want it more of a navy battleship kinda bluish gray. Maybe even lighter blue.
samelthecamel19
