Options for tuning of Gen1 TBI in 2023
gmbellew
Kansas city
glen
suburban 1500
Right, but allowed you to use blue tooth and phone vs laptop?
I use my phone with ALDLDroid and a Bluetooth OBD1 connector. you can export the csv files to your email and open in excel and save as an excel file.
mibars
Nadarzyn, Poland
Michal
Suburban V1500
Let's restart this thread :)
I've learned that in GMT400 TBI it is possible to convert from PROM memory to EEPROM using some adapter and you can even datalog via the ALDL port using TumerPro, as found in this thread:
Does any of you know if this same approach would work in a 1990 V1500 5.7 TBI?
What I understand is that I need an adapter like one of these:
Couple of 27SF512 memory chips (or a compatible one)
Plus a chip reader/writer
An ALDL 12 PIN cable like this:
Has any of you tried playing with TBI and have comments on the above?
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Not yet. I have the obd diagnostics 12pin to USB. I wanted to go in the dynamic-efi direction, but sadly Bob (Robert) passed away.
I plan on running aldl Droid to see where she is at. I'm expecting what tuning I may need will be done old school. If I see ( or think I do) eeprom seems like a better way to go.
There are tuners as noted above if you want to tune and move on.
For me the idea was to play and learn, and prep me for future efi tuning. Practically...back to the rabbit hole.
mibars
Nadarzyn, Poland
Michal
Suburban V1500
Wow, I was seriously considering that Flash 2 ECU, with a major drawback of having to ship an ECU for conversion. Sad to hear that.
But you got me reading on the ALDLdroid, that's one more interesting option to consider.
Speaking of my goals: I just want to try to tinker with engine management and see what can be done, maybe there are some HPs hiding and this will enable any possibility to do actual mechanical mods to the engine
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Yes I thought the ebl flash 2 would be efficient you can send logs and files back and forth to someone etc. not chips. I'm guessing you could do that with the eprom but not as easily. You have some tuners over there?
Look at megasquirt also.
At this point I'm hoping data tells me we didn't change enough, but we did mild (stockish) roller cam and compression.
Markgockley
