TBI/center bolt valve cover options
Scruffy49
Law Enforcement Navy
Rosemark TN
Jeff
C10 swb
4.3L
Found these on Fleabay.
https://www.ebay.com/itm/186737828145
They look pretty nice and less squared off than the typical center bolts.
Those are what is going on my carb conversion Vortec 350, with the passenger rear oil filler assembly off a factory carbed 4.3L V6… Replacing the stock solid “pop in” oil filler plug with a “pop in” breather… PCV will be in the driver side valve cover, plumbed to a 650cfm AVS2 “carbon dater”…;)
1lejohn
texas
john
k-1500, 2500 HD
How so?
Placement of the breather/pcv/oil fill is not critical. GM themselves moved them from location to location depending on the year and car/truck model. All that matters is that the breather is on the opposite bank as the pcv valve.
Here's two typical ways GM did it. The breather and PCV swapped sides and the oil fill was driver front or driver rear.
Those are the ones I'm running on my truck. The ones I had come from a 92 F-Body.
Gander
Army
Dirty Bay, TX
Lawrence
One thing I’m wondering about the center-bolt valve covers. The drivers side cover I’ve got doesn’t seem to be threaded for a screw-on cap and doesn’t have the cutouts for a bayonet-style cap. When I got the truck it just had a generic press-on rubber cap which was of course all dried out and seeping so I replaced it with a FC140 cap.
I’ve actually got a couple questions about it. First, has anyone else seen centerbolt valve covers with press-on caps? I’ve seen plenty with the plastic screw-on cap and I’ve seen a couple with the old metal bayonet blade style cap but I’ve never seen them with press-on caps before until this truck. Second, if anyone has, is there any way to use the oil filler extension you see on some of the later motors that use the center bolt style covers? Or do those extensions thread in?
Scruffy49
Rosemark TN
Jeff
C10 swb
4.3L
Look at 4.3s as your oil filler donor. You can also use a 4.3 oil filter adapter to gain clearance in tight installs, bolts right on to an sbc.
Centerbolt valve covers through L31 Vortec should bolt right onto a TBI Squarebody. And that is the thread in style straight oil filler pipe, requires a thin o-ring in the stand pipe base and in the cap for leak reduction. They still leak, hence, the sandcast tall ribbed covers going on my carb converted Vortec 350. That should be getting big block swapped instead, 350 in a 1t 4wd dually, smfh…
Nborden88
