nv4500 with long shaft np205
junkyardog05
Tennessee
Keith
454/ 400 turbo/ NP203
Can a stock nv4500 aluminum tailshaft housing handle the weight of a np205 transfer case? I have seen where you can buy a cast iron tailshaft housing, do I need it? I will be using the adapter / spacer from advance adapter also.
junkyardog05
Tennessee
Keith
Thats the adapter im talking about, but can the aluminum tail shaft housing of a 4500 support the weight of such a heavy transfer case?
slowgo
wa
Blake
V3500 3+3
454, nv4500, 205, 4.56 rp
Mine has been fine for several years now. Use the torque bars off the side of the 205 to the bell housing.to distribute some of the weight
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
I just picked up a 93 chevy truck that has a tbi 350 and nv4500 I want to stuff them in an older 1 ton so I will be doing this same swap soon
I have put a nv4500 in an 85 with a 208 t case but not one with a 205 yet
I am going to see if the short input for the 205 will work with the nv4500
slowgo
wa
Blake
V3500 3+3
Is that 93 external slave?
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
ya it is external slave
I was just looking at advance adapters site and seen a adapter for the long input cheaper than I can get a short input. so I just ordered a bell housing kit and the adapter for the long input round pattern 205.
I wanted to make this swap fast and easy the 1 ton its going in is a 4 speed truck already. I wont have to mess with the pedals or convert it to a hyd. clutch since I am using the AA bell housing.
fast and easy makes up for the money I just spent. really it would probably cost the same amount to adapt it any other way.
I ordered them from summit racing they had better prices and free shipping
460.00 for the bell housing kit and the 205 adapter
summit racing part numbers
bell housing kit
ADD-712577
long input round pattern adapter
ADD-50-6910
now I have to pull apart my round pattern 205 and swap out the slip yoke for a fixed yoke
junkyardog05
Tennessee
Keith
Mine has a torque bar on the passenger side only, is it supposed to have one on each side?
Also im needing a bell housing for the nv4500. I have already have the hydraulic clutch setup to install. My transmission is from a 1995 chevrolet truck
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
I would sell the bell housing from the 93 I just picked up with the master and slave for $150.00 plus shipping
I am guessing shipping would be 20 to 30 bucks to most places
junkyardog05
Tennessee
Keith
I just need the bell housing by itself
junkyardog05
Tennessee
Keith
Im pretty sure that 93 is external but not 100%. The short input shaft will work but I think you have to replace the rear tailshaft housing.
Can I use the stovk shifter on a np205, nv4500 combo or do I have to bo with the twin stick setup?
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
the nv4500 tail shaft does not have a mounting location for the shifter.
I am looking at the advance adapters bracket for the shifter to mount the stock shifter handle.
the short input will fit the nv4500 but you need to cut out a clearance wedge out of the mounting flange on the nv4500 and a little clearance work for the nut below the shifting rails.
and a little on the inside of the tail shaft housing for the bolts on the front of the 205
junkyardog05
Tennessee
Keith
The aa part number is 715529, summit racing sells them.
Corncob
