!!!!Need Np208 transfer case!!!!
firebane
Calgary, AB
Curtis
LOL well those are some ugly welds but if it holds awesome!
Georgeb
Wisconsin
George
K10 Burb Z71
Mig welder?
silverscottsk10
trafalgar indiana
mike
He can weld damn good, I don't think he does as much aluminum as he does steel
He has a tig welder but I think it wasn't working for him so he had to use a stick welder I believe
Georgeb
Wisconsin
George
K10 Burb Z71
I think that looks good for using a stick! should work fine.
MadOgre
NA
NA
NA
NA
NA
My apologies. The reason why welding cast aluminum usually fails is because the action of welding will draw in dirt and contamination from the pitted surface of the cast material surrounding the weld site.
I guess there is a simple way around this problem.
You simply need to get rid of the pitted cast surface surrounding the weld site and be meticulous in ensuring that no contamination is entering the welds.
And yes TIG Rod technique is actually one of the better ways to weld aluminum.
MadOgre
NA
NA
NA
NA
NA
Looking at that pic it looks like all the welds are full of contamination. So it will have to be redone or keep an eye out for another case. :sorry:
firebane
Calgary, AB
Curtis
That was the point! It allows him to run it so he can look and not be stressed.
Georgeb
Wisconsin
George
K10 Burb Z71
What type of failure are we worried about happening?
silverscottsk10
trafalgar indiana
mike
Can't get a full overhaul kit, it's discontinued, anyone know where to look for one?
silverscottsk10
trafalgar indiana
mike
Input shaft bearing, the only one that's bad, is it common for these to go out?
Cuz the other case I bought it was out as well
silverscottsk10
trafalgar indiana
mike
They look to be about the same quality, I guess I don't have much choice though
MadOgre
NA
NA
NA
NA
NA
Randy's Ring & Pinion / The Gear Center will sell you a good quality full rebuild kit for a $100 or so. Ours is the 208C.
silverscottsk10
trafalgar indiana
mike
The 208c 208f 208d 208j kits have all the same parts it looks like though, power train warehouse has a rebuild kit for 87$ I believe
Stickman
