need engine help
jelly69
portland oregon
Austin
v2500 suburban
5.7 liter
I have an 89 5.7 Tbi And im trying to pass dew but I believe I have a miss im looking to up grade my ignition any recommendations?
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Just stick with AC Delco parts. Did you take an emissions test and fail or just prepping for it?
Yes please use ACDelco replacement parts!
jelly69
portland oregon
Austin
v2500 suburban
5.7 liter
Well two years ago it failed and my dad just registered it out in the boonies. That's no longer an option and acdelco parts are too dang expensive like 10 dollars for a spark plug and almost 100 for an o2 sensor I make minimum wage so I can't afford that
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
I don't know where you got 10 bucks for a spark plug they are 2.29 for a stock replacement for a tbi motor
http://www.oreillyauto.com/site/c/s...e=Chevrolet&model=R10+Suburban+RWD&vi=1300790
if you put anything in it but ac delco you will be replacing them sooner costing you double
just use ac delco and get it over with
shop ebay they have good prices for ac delco stuff
no I am not a die hard ac delco fan but I do believe in using oem parts I would use autolite spark plugs in a ford
gpmorgan
Tupelo Ms.
greg
I've seen it over and over. When you use the over the counter parts, chances are you will be replacing them again in the near future. That has been my experience. There are some after market parts that are dependable (mallory, msd, accel) but you don't save any on the cost. SO for me, OEM and after markets mentioned are the only way to go.
jelly69
portland oregon
Austin
v2500 suburban
5.7 liter
Ok so next question it is running rich how can I adjust the air fuel or fix the richness. also the manager at the auto store said that no was on of the best plugs and that he ran them on his 78 Chevrolet is n gk any good it was suggested to go a heat rating hotter is this a bad idea?
How do you know it is running rich, is it blowing black smoke?
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
You still running the original catalytic converter? Mine was just a burned-out shell at 150k and replacing it made a huge difference on emissions.
jelly69
portland oregon
Austin
v2500 suburban
5.7 liter
I can smell fuel in the exhaust and we just replaced it a few years ago so its not the cat I'm going to put on a new o2 tomorrow along with plugs anything else I should change
jelly69
portland oregon
Austin
v2500 suburban
5.7 liter
So tested the compression I have no compression in the number 1 cylinder hahaha need a new engine
Pull the valve cover off the dead cylinder and check the rocker arms condition and the movement of them is correct.
MrMarty51
Eastern Montana
Martin
Could be a valve is stuck open causing the loss of compression, if a valve is stuck open on that cylinder then give it a tap with a hammer, it`ll probably snap shut. Also, if there has been that much fuel passing through the cylinders, the compression will likely not be up to what it could be. Get the engine to running and change the oil immediately, there will be a lot of gas in the oil and can cause the engine to seem like it is running rich when in fact it is the gas, clinging to the cylinder walls and components that is making it run rich.
Burning that rich will more than likely be the O2 sensor.
Have You checked the dist. cap and rotor. If there is an blackish carbon looking stuff built up on the rotor and inside of the cap then replace the plug wires too.
I use Delco when I can get it, I have tried the "Standard" parts and they seemd of a good quality and they lasted, IE, the plug wires, dist, cap and rotor.
jelly69
portland oregon
Austin
v2500 suburban
5.7 liter
So what all goes into pulling off the valve cover also all other cylinders tessted above 150 psi some at 170
imyourhuckberry
