gmbellew
- May 27, 2018
- Kansas city
- glen
- suburban 1500
hope th
hope they get it figured out. sounds like that new TB might have some sort of other issue. hope you also gave them the old one to help trouble shoot.I researched the IAC reset procedure and tried it multiple times as described above. It seems to idle fine and I can adjust it with the IAC disconnected (with the new TBI). When the IAC is connected back up is when the idle goes crazy. It starts out idling really low almost stalling, then goes really high a minute later. All connections are good or new. I have ordered and replaced many of the connectors. And the fast idle does not work with the new TBI when cold.
What really baffles me is how different the two TBI's are from each other and how the truck runs. The old TBI it runs better overall and has a good fast idle when cold but the idle hunts up and down when hot no matter what. And it won't idle at all when I try the IAC reset procedure. The new one the idle is so erratic with the IAC connected and mostly idles at 1800 RPM. I can't adjust it down. And the fast idle does not work at all.
I unfortunately reached the end of figuring it out. It's at a local shop now. The guy is very knowledgeable with TBI's and older systems. Worst case if he can't figure it out he said he can convert it to carburetor. About 1500. It will probably be there a month as things there take time and he has a lot of trucks he's working on. I'll report back what he finds outs so that if anyone else runs into this issue they will get an easier and faster solution.
