LWB driveshaft question
82SquareBurb
Soddy Daisy TN
Derek
Anyone with a long wheelbase truck/Suburban running a one piece driveshaft? I snagged a 5" .125" wall unit out of a 2013 2500 Silverado for a deal. My hope is to have a local shop shorten/balance it to the ~70 inches I need and delete on the 2 piece drive shaft setup in my C10 Suburban.
I think @xm20k runs a 5" in his rig, was curious if any long wheelbase trucks are running one and if this is a solid solution for max towing power/ HD use. Looking for insight, as I fear the steel 2 pc setup will fail, just by how janky the carrier bearing mounts. Looking for ideas. Thx!
legopnuematic
Licensed Junk Dealer
MO
Spencer
Both my 76 and 79 C10's, both LWB (and both TH350's) are factory 1pc drive shafts. The 85 C10 (305/TH350) I had parted out was also a 1pc shaft.
1lejohn
texas
john
k-1500, 2500 HD
85 K 10 one piece steel shaft. Was a 700R , now a 350. No problems
83K31003
Florida
Tom
K31003 K30 Cab Chassis
‘80~’88 K-30’s with a regular cab and a fleetside bed SRW & DRW ran a two joint slip yoke shaft setup that was steel but only 4” diameter ( and thinner wall ).
Crew Cabs and longer wheelbase Cab Chassis’ used a 3 joint carrier bearing shaft setup but not the 131.5” W/B K-30’s of those year models.
And plenty of 4WD K10/20 LWB Squares in the seventies utilized a two jointed type rear shaft.
Most K-10’s were 3-1/2” diameter and’73~’75 K-20’s were 4-1/2” diameter.
There were some later seventies models that used a three jointed type carrier bearing setup with smaller diameter tubes but your big aluminum 5” diameter thick walled shaft should work just fine.
HTH’s, Tom
xm20k
Girard, Ohio
Mine is an aluminum 5" at 72.5" center to center but that's because no one would build a steel one longer than 60" for over 500HP. Best bet would be to talk to someone like https://www.actionmachineinc.com/ who build drive shafts for a living for everything from stock to high power off roaders and drag vehicles.
82SquareBurb
Soddy Daisy TN
Derek
Thanks for confirming. Looks identical to the one I have.
Yeah I knew I had a problem when Mark Williams' told me to pound sand when I told them what I need. I think they only use 4" .083" wall stuff, so they limit to 60" or so.
When I talked to some turbo LS swap Burb projects, the setup is 1 pc later Silverado/2500 5" shafts cut down to fit, and they seem to hold up fine. If my math is mathing correct, I need a 5" .125 wall tube to hold a critical speed of 6,000+ with around 800+ foot pounds for ~70". Will have my local shop confirm on my math.
83K31003
Florida
Tom
I miss read the 2WD and 72” tube portion - I was thinking this was a 4WD application with a shorter tube dimension. My apologies, Tom
Carb'ed Vortec 350
It appears from the replies c10 has one-piece, and c20 and heavier get two-piece. I have only had c20s and they all have two-piece.
Bloodhound1981
Law Enforcement
MA
Rusty
C-10
I have a 1981 C10 longbed with a factory one piece driveshaft. I replaced it with a 5" aluminum. The weight difference is unbelievable.
82SquareBurb
Soddy Daisy TN
Derek
Yeah it seems GM switched depending on the application. Wondering how the center carrier crossmember clears when switching from 2pc driveline to a 1pc - as I want to avoid cutting it out and making my wet noddle C10 frame any more noodly lol If I can retain it, would make a good safety loop mount as well.
82SquareBurb
Soddy Daisy TN
Derek
Very nice, love that bed liner as well.
Do you recall the Cap-Cap length for the long bed? C10 Suburbans come in about 72" for the stock 2pc driveline with a 700R4.
xm20k
Girard, Ohio
70" I believe with a TH350 mine is 72.5 due to the powerglide. Mine only came close to the cab floor directly under the seat area but a BFH solved that issue with a small dent.
82SquareBurb
Soddy Daisy TN
Derek
Looks like a stout setup.
Looks like this one will need at least one 1350 yoke for the rear joint at least. These 1480 U-Joints are a bit overkill and no way I know of to convert to the 1330 yoke, will see what they can do with it when I have it shortened. This one is out of an Allison truck so the yoke is a 34 spline, not 32. Ironically this one is 71.5" cap to cap - so not sure if it will work or not yet. Definitely a beefy driveshaft.
Joestreml
