LWB driveshaft question
82SquareBurb
Soddy Daisy TN
Derek
Anyone with a long wheelbase truck/Suburban running a one piece driveshaft? I snagged a 5" .125" wall unit out of a 2013 2500 Silverado for a deal. My hope is to have a local shop shorten/balance it to the ~70 inches I need and delete on the 2 piece drive shaft setup in my C10 Suburban.
I think @xm20k runs a 5" in his rig, was curious if any long wheelbase trucks are running one and if this is a solid solution for max towing power/ HD use. Looking for insight, as I fear the steel 2 pc setup will fail, just by how janky the carrier bearing mounts. Looking for ideas. Thx!
legopnuematic
Licensed Junk Dealer
MO
Spencer
Both my 76 and 79 C10's, both LWB (and both TH350's) are factory 1pc drive shafts. The 85 C10 (305/TH350) I had parted out was also a 1pc shaft.
1lejohn
texas
john
k-1500, 2500 HD
85 K 10 one piece steel shaft. Was a 700R , now a 350. No problems
83K31003
Florida
Tom
K31003 K30 Cab Chassis
‘80~’88 K-30’s with a regular cab and a fleetside bed SRW & DRW ran a two joint slip yoke shaft setup that was steel but only 4” diameter ( and thinner wall ).
Crew Cabs and longer wheelbase Cab Chassis’ used a 3 joint carrier bearing shaft setup but not the 131.5” W/B K-30’s of those year models.
And plenty of 4WD K10/20 LWB Squares in the seventies utilized a two jointed type rear shaft.
Most K-10’s were 3-1/2” diameter and’73~’75 K-20’s were 4-1/2” diameter.
There were some later seventies models that used a three jointed type carrier bearing setup with smaller diameter tubes but your big aluminum 5” diameter thick walled shaft should work just fine.
HTH’s, Tom
dpenfield
